Solid axle swap
Old 01-20-2012, 07:32 PM
Dunnrightmobile's Avatar
Dunnrightmobile
Dunnrightmobile is offline
Solid axle swap
So iv decided to do this swap on my 95 flair side. Iv seen a few pictures and general instructions on doing this. I found my axle (78 bronco)already and will start this project in a month. Does any one have any tips or suggestions from previous experiance?
Old 01-20-2012, 11:25 PM
Jhan85f150's Avatar
Jhan85f150
Jhan85f150 is offline
I would highly recommend heading over to fullsizebronco.com and checking out the sas forum over there, they have every answer, tip, and trick in the book from half ton to one ton from leafs to coils to 4 link.
I have been lurking over there myself trying to learn all I can so that i'm ready when the time comes for me to slap some one tons under my 85.
Old 01-21-2012, 12:16 AM
Dunnrightmobile
Are u putting 44s on ur truck or some thing??
Old 01-21-2012, 06:27 AM
blucollar4xford's Avatar
blucollar4xford
blucollar4xford is offline
Just some food for thought, check this thread out:
-1) https://www.ford-trucks.com/forums/1...tb-thread.html
If you're still dead set, there is all sorts of info here:
-2) https://www.ford-trucks.com/forums/7...ch-thread.html
And among that thread, you'll find these (among other useful info):
-2a) https://www.ford-trucks.com/forums/8...wap-guide.html
-2b) https://www.ford-trucks.com/forums/7...-write-up.html
...hopefully this helps!
Last edited by blucollar4xford; 01-21-2012 at 06:32 AM. Reason: Double posted link
Old 01-21-2012, 06:36 AM
blucollar4xford
Also, I'm in the "gathering parts" phase of SAS'ing my 88 ranger to run 38's on it. Also running 78 bronco axles.
Old 01-21-2012, 09:11 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
You need at least 4" of lift to run the solid axle
Old 01-21-2012, 09:57 AM
Dunnrightmobile
Iv gotta a home made 6" lift in front. What kind of spring packs do u guys use inthe back to get these things higher.? Iv snapped a few springs in the back an want to replace the any way.....
Old 01-21-2012, 02:39 PM
Jhan85f150's Avatar
Jhan85f150
I'm probably not gonna run bigger than 38's, but I have a heavy foot and a pin it to win it kind of driving style so want the extra strength of one tons. That and at some point my 351 cleveland will be twin turbo'd so i'm gonna need some serious strength for that
Fabman54
Large Truck
08-25-2014 08:08 PM
tbirdage
Offroad & 4x4
28
02-02-2011 04:17 PM
ProjectF1056
02-20-2007 12:18 PM
81fordf-250
02-03-2007 01:08 PM
Pi Fox mP
12-30-2003 05:18 PM
Quick Reply: Solid axle swap
