Crank no Start.
Crank no Start.
Hopefully I can get some good direction. I have a 92 f150 4.9l straight drive and yesterday driving down the road the engine just stopped running. I have power everywhere. Checked for a spark and I have none. Thought the coil was bad and replaced it but still no spark. The truck has 180,000 miles and a lot is still factory parts. Any help is thanked.
Might be ICM or PIP, especially if starts/runs after it sits a while?
What exactly do you mean by "I have power everywhere", safe to assume that includes power to the coil during the no start/no spark condition?
Do you hear the fuel pump run for second or so when first turn the key to run?
Won't start, "no spark" I'd pull the ICM take it to nearest auto parts can test it, have em test it a minute. I'd start with it as its easiest to remove of the two, ICM/PIP. Both equally can cause same result.
If it tests bad get a new one, if tests good well then its probably gonna be the PIP in the dizzy.
In your favor its not likely to get a false test result as "good" (known issue when testing those) you don't have an intermittent problem to cloud the issue Pass/fail.
Many time's it will pass in their testing machine and still be bad, if it passes their test and your still having a problem, and if you want to do some testing yourself, read through this link all 5 pages, that should pin point the fault ...good luck Part 1 -Ford Ignition Module Test. Fender Mounted Module (ICM).
Great link there Slip ford man, tried to hit your rep but alas was denied yet again.
Well I spent the day doing test and swapping parts and now feel like a real dummy. I stated at the very begining that i could hear the fuel pump but it wasnt the pump it was the fan motor. Sorry. I did all the 5 pages of the test which where in the link and it led me to the ICM bad. even thought 2 parts stores said it was good I bought a new one and still no start. I then had daughter cranck the truck while I pushed the schader valve on fuel line and nothing comes out. I found another Thread where someone had the same problem and was told to disconnect 60 pin connector at the PCM and if you have spark the PCM is bad. It started raining so I am going to pull PCM tommorrow and get tested . If this is in fact true hoopefully it will work.
Pigpendirtface08
05-21-2017 07:14 PM
BS51993
01-27-2017 03:42 PM
john-h_schmidt
01-28-2007 04:03 PM
