2004 6.0 diesel white smoke
Old 01-09-2012, 06:46 PM
stacy h's Avatar
stacy h
stacy h is offline
My 2004 superduty 6.0 just started puffing out white smoke. It seems to do better once it has warmed up(gauge half way between cold and hot) is this a bad fuel injector or just a clogged one. Put an additive in today when I filled up so I will see what it does.
Old 01-09-2012, 07:22 PM
BobbyB's Avatar
BobbyB
BobbyB is offline
It could be the EGR cooler leaking coolant into the intake. Park overnight on a downhill slope and remove the EGR valve. If the intake is wet inside, the EGR cooler is probably leaking.
Old 01-09-2012, 09:35 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Moved to the 6.0L Powerstroke Diesel forum.
Old 01-09-2012, 09:42 PM
Shaneb75's Avatar
Shaneb75
Shaneb75 is offline
Strokin Okie
Does the smoke smell sweet like coolant, or does it have a raw diesel smell?
Old 01-10-2012, 04:07 AM
StrokinWarmblood's Avatar
StrokinWarmblood
StrokinWarmblood is offline
Could be either fuel or coolant related. Depending on the smell as was stated above. So first thing, have somebody rev it WOT for a second and stand back there and smell. If it smells sweet or fishy, that is coolant. If it smells like a mixture of fuel and exhaust, it's obvious the issue. Have a look at your degas bottle and look for obvious loss of coolant (it should be at the min line), or discolored coolant. Next, check your oil and see if there are any bubbles or milky substance on the dipstick. Hopefully it goes ok, good luck.
Hellpmy4ord
11-19-2016 07:19 PM
Johnnyblaze
08-31-2013 03:51 PM
Barney58
01-23-2011 09:07 PM
FordSDF250
06-30-2009 10:58 PM
abosko
01-28-2009 12:35 PM
Quick Reply: 2004 6.0 diesel white smoke
