FEW-14429-A cigar lighter fuse rating
Old 01-06-2012, 12:42 PM
wjslam's Avatar
wjslam
wjslam is offline
I have a 76 F100 with an aftermarket lighter/12v powerpoint socket. Most any load I put on it blows the 15A fuse in the fuse box. I read in the forums where all the lighter sockets from 56-80 have a fuse on the back (FEW-14429-A). Are they available NOS? Haven't been able to find one so far. Also, what is this fuse rated for? I can wire in a fuse in the interim until I can find the right part or salvage a lighter socket from the boneyard.
Old 01-07-2012, 02:17 PM
wjslam's Avatar
wjslam
wjslam is offline
Ok...got the problem solved. The aftermarket lighter socket metal pieces that grip the lighter element were being pushed into the collar of the socket, causing a dead short. I solved the problem by rolling up a business card and slipping it into the collar to form a liner, then installed the collar over the lighter socket. That way, the socket and collar cannot make contact even if an accessory socket is a bit of a tight fit. Works lika a champ.
Old 01-07-2012, 02:20 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
Thanks for the follow-up; was curious about that one.
Old 01-07-2012, 02:24 PM
wjslam's Avatar
wjslam
wjslam is offline
It just about drove me nuts until I noticed a tiny blued burned spot on the socket "spring." Maybe a moderator can change the thread title to something more helpful for folks searching for a similar problem.
WootDogg
1997 - 2003 F150
15
09-27-2020 04:54 PM
ncguy23
Electrical Systems/Wiring
07-27-2007 03:33 PM
honkytonk
05-26-2007 01:52 PM
ghades
05-19-2005 08:12 PM
kms910
1997-2006 Expedition & Navigator
05-27-2004 02:56 AM
Quick Reply: FEW-14429-A cigar lighter fuse rating
