I Ton front
I Ton front
I just pick up a 1965 f350 I6 W/ 6092 ACTUAL MILES...
This question probably best suited for NumberDummy but anyone can join in. I been thinking a lot about the 6 lug problem that all 1 ton owner face. Wouldn't it be feasible to install a 1964 f250 front I-beam in place of the 1 ton on my 65. If I unstand it correctly it should be pretty much a bolt in and would end up with the 8 lug wheel pattern. Or am I all wet.
If you're running singles here's a thought. It will take some measuring to make sure you have proper wheel clearance, but think about this. The bolts holding the front brake drum on are 8 on 6.5, just like wheel lugs. I cut the 6 lug flange off mine and bolted the adapter seen in my last post to the 8 lug flange for dually type wheels on the front. Serrated wheel studs can be had in almost any size and will press through the drum and hub. Bolt on your lug centered wheel and there you go. Mine was more complex but worked really well. A machine shop could chuck up the hub and cut away the 6 lug flange. Like I said, just a thought, since many here that know far more than me say an axle swap doesn't work on these trucks ......
Pickupmanx2
06-29-2014 10:12 PM
hoobatech
04-29-2008 04:36 AM
