8 lug wheels
Old Feb 21, 2005 | 01:30 AM
randylay's Avatar
randylay
8 lug wheels
I inherited a 61 f100 uni that I was told had an upgraded suspension, to a 3/4 ton. All I know for sure is that it has 8 lug wheels. Can anyone tell me what is really under this old truck? My grandpa had done a lot of fabricating and upgrades, but that all had to be pre 1980. Anyway, thanks for the help.
Old Feb 21, 2005 | 04:42 AM
jowilker's Avatar
jowilker
Randy, the 8 lugs is a give away. 1/2 tons use 5, 3/4 & 1 ton trucks use 8.
John
Old Feb 21, 2005 | 08:25 AM
FordBoypete's Avatar
FordBoypete
Randy,
I concur with John 100%. 5 lug set up thru 72 was 1/2 ton & 8 lug either 3/4 ton or 1 ton set ups.
Also trucks before 1973 [57-72 F series] had narrower axle assemblies, trucks 73 & after are wider. It goes for both single and dual rear wheel set ups. Although I don't believe any OEM 3/4 ton (F-250) Dually were made by FoMoCo at the factory.
Without some dimensions, ID Numbers, or other information to go on, what I say would be a presumption. The easiest swap I know of would be to use F-250 axle assy's & suspension from a 57-72 year model as it is pretty much a bolt up deal.
Also FWIW & if you're interested, F-250 4X4 set ups, thru 72 also are bolt up as far as axles & suspensions are concerned. You could use F350 4X2 or 4X4 stuff but F350 dually rear is a lot narrower to allow for a extra wheel in dually set ups.
FBp
Old Feb 21, 2005 | 11:57 AM
randylay's Avatar
randylay
Thanks Guys. What drove my question is that I would like to put disc brakes on the front. I have seen posts about a spindle bolt on conversion and am trying to be sure that I look for and get the right parts to do the conversion w/out changing the straight axle.
Old Feb 21, 2005 | 12:39 PM
garbz2's Avatar
garbz2
The 61 F100 spindle and F250 Spindle are the same diameters for the races, however i have not found anyone who produces a kit to keep the 8 lug wheels. all the replacment kits are 5 0n 5.5 or chebby 5 0n 4 3/4
There is no direct spindle late model bolt on that will work with the straight axle.
In the rear do you have a spicer/Dana or nine inch? lots of trucks had the old JC witney aluminum 5x8 lug conversions. check and see actually what rear is in place.
Garbz
