1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
fluid in spark plug well #3 help!
Old 12-26-2011, 03:54 PM
dadanny7735's Avatar
dadanny7735
dadanny7735 is offline
went to change plugs and cop coils today and found a little bit of brown fluid in well #3. i was wondering where I should check for leaks.
Old 12-26-2011, 10:41 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
There are seals at the area of each plug hole and the cylinder head and to fix your leak you will have to remove the cover and install new seals. A bit of a PITA and not always neccessary unless the oil shorts the plug(s) causing a miss. You could just vacuum the oil out before removing the plug to keep it out of the engine. If you keep the truck you will have to replace the seals eventually.
Old 12-27-2011, 02:31 AM
alloro's Avatar
alloro
alloro is online now
Received 4,199 Likes on 2,434 Posts
If the heater hose runs above cylinder 3 you'll want to check the hose connection for any signs of leaking.
Old 12-27-2011, 06:02 PM
dadanny7735
Thank you guys! I thought the fluid smelled like gas. I'm hoping the previous owner spilled some while relieving the fuel pressure. I'm gonna take your advice and vac it out. then wait to see if it comes back. I'll check for that pesky leaking heater hose that always leaks in their too. Thanks again. I'll let you know how it turns out.
Old 12-28-2011, 03:00 PM
alloro's Avatar
alloro
I wouldn't vacuum it out if you think it's gas...BOOM. You're better off shoving a rag down there to absorb the gas.
Old 01-03-2012, 06:37 PM
dadanny7735
Thanks for the responses. turns out I got VERY lucky, the spark plug actually loosened up and backed out. thankfully there was no damage to the threads. I have heard so many stories of spark plugs spitting out and stripping the threads.
frank f150
12-11-2010 12:16 PM
aceltx09
Modular V10 (6.8l)
08-20-2010 10:05 AM
NitroNate
1997 - 2003 F150
01-27-2010 06:31 PM
Wilbert
Modular V8 (4.6L, 5.4L)
06-28-2005 10:26 PM
montster
07-13-2003 05:50 PM
Quick Reply: fluid in spark plug well #3 help!
