1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2005 F250 4x4 - Torques needed for Rear brake parts
Old 12-26-2011, 10:21 AM
whalerron's Avatar
whalerron
whalerron is offline
I have a 2005 F250 4x4 and I need the torque settings for the various bolts on the rear. I need torque values for the following parts:
4 Backing plate retainer bolts
2 Caliper bracket retainer bolts
2 Caliper slide bolts
8 Axle retaining bolts
Thanks,
Ron
Old 12-26-2011, 05:03 PM
joe_r_dog's Avatar
joe_r_dog
joe_r_dog is offline
i just did backing plates and i didnt and dont ever properly torque the bolts. the only one i torque properly are the spindle nuts that hold each hub on. i just get em really tight. lol but here ya go.
Torque Specifications Rear
Description (lb/ft)
Disc brake caliper pin bolts — Excursion, F-250/F-350 with Ford and Dana axle = 27
Bleeder screw — Excursion, F-250/F-350 with Ford axle = 8
Rear wheel disc brake adapter bolts — Excursion, F-250/F-350 with Ford axle = 150
Rotor shield bolts — Excursion, F-250/F-350 with Ford axle = 8
Rotor-to-hub bolts = 94
Disc brake caliper anchor bolts = 128 lb/ft
Stone shield nuts = 46
Old 12-26-2011, 10:26 PM
whalerron's Avatar
whalerron
Thanks for the numbers. Do you have the values for the 8 axle retainer bolts which hold the axle to the hub?
Old 12-26-2011, 10:45 PM
joe_r_dog's Avatar
joe_r_dog
heres a great write up
https://www.ford-trucks.com/forums/7...ake-shoes.html
sorry cant find the sceps. i just used my built in torque wrench.
Old 12-26-2011, 11:01 PM
whalerron's Avatar
whalerron
I have one of those built-in torque wrenches too but as I age, I have noticed that it is getting weaker!
Do you have any hints about the new style hub retaining nut? I had an 1967 truck which used 2 locknuts to hold the hub in place. The nuts were straightforward to tighten.
Then I had a 1984 truck which used a single locknut that had a nylon insert. The nut was tightened and then a key was driven into the nylon insert to hold the nut in place.
This 2005 truck has a multipart locknut which appearently contains a locking mechanism of some sort. Do I need to do anything with it other than use the locknut tool to tighten it? Do I need to put inward pressure on the tool to disengage the locking mechanism?
Thanks.
Old 12-26-2011, 11:38 PM
PowerStrokeHD's Avatar
PowerStrokeHD
PowerStrokeHD is offline
Not sure where joe_r_dog acquired his torque values from, but they are not accurate for a '05...
4 Backing plate retainer bolts - 101 lb/ft (137 Nm)
2 Caliper bracket retainer bolts - 203 lb/ft (275 Nm)
2 Caliper slide bolts - 26 lb/ft (35 Nm)
8 Axle retaining bolts - 80 lb/ft (109 Nm)
As for the hub nut, nothing really special there. Just tighten to 60 lb/ft (81 Nm) while rotating the hub occasionally, then adjust as follows.
New Bearings - Ratchet back 5 teeth/notches (1/8 turn) on the hub nut.
Used Bearings - Ratchet back 7 teeth/notches (1/6 turn) on the hub nut.
Old 12-27-2011, 07:48 AM
whalerron's Avatar
whalerron
Thanks, PowerStrokeHD. Last night, I picked up a Haynes manual and your values correspond to those numbers which also match up with torque values I found in another thread here. Now I feel like I have the correct values.
I want to make sure I have the terminology right too because I am replacing the rear backing plate assemblies which have rusted out ( this should be a whole other rant thread). Are my below descriptions correct?
Backing plate retainer bolts - these are the 4 nuts which mount the backing plate assembly to the axle housing.
Caliper bracket retainer bolts - these are the 2 bolts which fasten the caliper mounting bracket to the bracket which is part of the backing plate assembly.
Thanks for the help.
Old 12-27-2011, 08:52 AM
PowerStrokeHD
Close enough on the terminology...
Backing plate retainer bolts aka Brake Caliper Support Bracket Bolts.
Caliper bracket retainer bolts aka Brake Caliper Anchor Plate Bolts.
Benchwrench
06-11-2014 08:10 PM
dfink12345
10-19-2011 06:51 PM
okiebronco
09-26-2003 05:15 PM
okiebronco
07-02-2003 11:16 PM
Quick Reply: 2005 F250 4x4 - Torques needed for Rear brake parts
