1991 ford f150 steering issue
Old 12-23-2011, 08:26 AM
countyboy22's Avatar
countyboy22
countyboy22 is offline
On my 91' f150 xlt lariat, it has the 2.5 inch leveling kit, and is on some bald 32's, My question is how come the steering doesnt correct all the way, it goes to about the last half turn then you have to manually correct it. Any suggestions would be appreciated!
Old 12-23-2011, 10:24 AM
76250_4x4's Avatar
76250_4x4
76250_4x4 is offline
more than likely you need your alignment checked and adjusted. i believe this would be caused by the castor being off. however with 2.5 inches of lift in the front i would say that the adjustment of your castor/ camber bushings may be limited as they are probably set more to adjust the camber issue
Old 12-23-2011, 05:38 PM
countyboy22
Could a seized upper/lower ball joint cause this problem as well?
Old 12-23-2011, 06:07 PM
76250_4x4's Avatar
76250_4x4
I would think if that was the case the steering would be difficult all the time.... Not sure though
Old 12-24-2011, 08:12 AM
countyboy22
The steering is fine as can be until that last half turn like i said earlier, so im sure that it just needs the alignment like you stated, truck hasn't been able to get a sticker for awhile so im working on it so i can get it on the road.
Old 12-24-2011, 08:51 AM
76250_4x4's Avatar
76250_4x4
Also something else to think about, if it sat for a while the steering gearbox can get stiff (sticky) or if someone ever adjusted the screw ontop of the steering box too tight. Just some other ideas for you
Old 12-24-2011, 12:35 PM
countyboy22
I'll Look into that, thanks again!
daniel044
2017+ Super Duty
10-16-2017 03:01 PM
mgoolsby
2017+ Super Duty
02-24-2017 08:35 AM
galena
1999 to 2016 Super Duty
04-03-2011 11:54 AM
nlfireblade
2004 - 2008 F150
07-21-2009 02:13 AM
matt hesley
13
01-13-2004 12:57 PM
Quick Reply: 1991 ford f150 steering issue
