instrument cluster change out
Is it true that you can't trade out an instrument cluster on the F-150 from one vehicle to another? I have a friend that his odometer will not work (bad sodering) ,it kicks in once in a while but most of the time it does not light up,He found another cluster but was told it wouldn't work any truth to this sounds like bull to me but would appreciate a Technition to chime in.
I had to change mine out. It will have to go to dealer and be reprogrammed. If you want to knock a few miles off the odometer, now would be the time to do it since you can put any number you want when it gets programmed (don't actually do this). I went with a new cluster, but I don't think buying a used one would be a problem unless the dealer won't install a used one.
keld
1997-2006 Expedition & Navigator
01-18-2005 02:12 PM
2008, aftermarket, buy, changing, cluster, clusters, excursion, expedition, f150, ford, forum, instrument, light, powered, vbulletin
