what's the right battery size
Old 12-21-2011, 03:25 PM
Swagtastic's Avatar
Swagtastic
Swagtastic is offline
So my V10 has been having hard starts lately. So had the Batt and Alt tested = good. Starter = good. So there I found myself hood up staring at the engine thinking what else could it be. And you know what, the Battery is signifigantly smaller than tray would allow. And i'm pretty certain it's not the same specs as the battery that was in there originally. So besides CCA (which mine has 750) what battery should be in there? Also, i plan to add lights, a winch and some audio equipment in the future and may as well get a battery (and alt if needed) that can run all that. Thoughts
Old 12-21-2011, 03:40 PM
LivingLarge's Avatar
LivingLarge
LivingLarge is offline
I Use a Motorcraft MAX
BXT 65 850
Thats a series 65 Battery with 850 cold cranking amps
Old 12-21-2011, 03:52 PM
njneer1's Avatar
njneer1
njneer1 is offline
Bigger is better when it comes to batteries......get the most CCA's you can. there will be 10k people chime in for different brands......on my diesel I run 2 Everstart Maxx batteries from Walmart.....Why ? CCA: 875 amps @ 0 degree F/ CA = 1090 amps @ 32� F; Reserve capacity: 165 mins.....plus 3yr free replacement, 108 month pro-rata.....plus I can make a wrong turn off any interstate and end up in a Walmart parking lot to get my replacement with no questions asked......
You might shoot a PM to Sean (WPNAES) ......he has dual batteries on his V10 and with your future additions planned it might be a good idea for you.
Old 12-21-2011, 03:58 PM
LivingLarge
Ford warranty the same, 3 year free replacement or 100 months pro rated.
Love the setup WPNAES has!!
Old 12-21-2011, 04:16 PM
gr8scott72's Avatar
gr8scott72
gr8scott72 is offline
Not the same warranty on Sunday.
Old 12-21-2011, 04:38 PM
LivingLarge
Good one Scott, Ford here in Fort Lauderdale is open 7 days. But what your saying is true you cant beat 24/7...
I guess I'm just an OEM Nut!
Old 12-21-2011, 04:48 PM
Peace2Peep's Avatar
Peace2Peep
Peace2Peep is offline
I did a couple of super strong batteries for my various future and current improvements. Plus my kids like to leave different lights on inside my truck:
https://www.ford-trucks.com/forums/1...l-upgrade.html
A little pricey, but worth it in my opinion
Old 12-21-2011, 06:51 PM
njneer1's Avatar
njneer1
njneer1 is offline
My point Exactly ! The everstart maxx actually gets decent marks from consumer reports.
Old 12-21-2011, 07:32 PM
LivingLarge
I thought the question asked was what size battery belongs here??
I showed oem... Not walmart.
Old 12-21-2011, 08:04 PM
njneer1's Avatar
njneer1
njneer1 is offline
you showed that......... 65 series.....he also asked about CCA's....Motorcraft doesnt make batteries ......Motorcraft batteries are made by Johnson Controls and so are the everstart batteries..... largest domestic battery manufacturers are Johnson Controls (Interstate, Motorcraft, Energizer, older Diehards), Delco (Sears, newer Diehards), GNB (Champion) and Exide (NAPA).
Old 12-21-2011, 08:47 PM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
a garbage fleet diesel mechanic told me they use the 700 cca batteries, because the plates are thicker and last longer according to him.
Old 12-21-2011, 09:14 PM
robert_l_ross's Avatar
robert_l_ross
robert_l_ross is offline
I personally have a 1000 CCA Bosch. Battery was low when I got it, started showing signs when the first "cold" spell came...working on the truck with doors opened left me unable to turn it over without a jump starter battery, so it was time to replace.
I don't know much about batteries though, just found the highest CCA I could find and got it - knowing I would be adding an inverter and doing a bunch of upgrades.
Y2KW57
Escape & Escape Hybrid
18
08-11-2018 03:32 PM
Pitcrw6
21
11-29-2016 09:50 AM
gb'sfx4
01-25-2012 03:40 PM
boggerted
27
08-05-2007 11:26 PM
bluthunder
18
02-24-2007 10:15 PM
Quick Reply: what's the right battery size
