motor swap head questions
Old 12-21-2011, 12:23 AM
pritchett's Avatar
pritchett
pritchett is offline
ok i have a 93 f150 with the original 5.0 in it and the motor gave out and bout a year ago my buddy gave me the 5.0 motor out of a 88 f150 and im trying to figure out which heads are better the ones out of the 93 or the ones out of the 88 id like to know which ones would be better thanks for all the help
Old 12-21-2011, 04:27 AM
lew52's Avatar
lew52
lew52 is offline
I think they both will have E 7 heads , if not use the 93 heads...
Old 12-21-2011, 04:30 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
Lew is correct, both engines have E7 heads unless someone has done a head swap on either of them in the past. They should be identical.
Old 12-21-2011, 10:05 AM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
sell the 88 5.0 and get a 5.8 and swap that over.
Old 12-21-2011, 11:20 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
couldnt agree more with this guy.
then ditch the e7's for gt40's or better.
Old 12-21-2011, 11:31 AM
pritchett's Avatar
pritchett
ok thanks for answering the question guys but right now im going to keep the 5.0 in it because i cant find find a 5.8 to buy and i dont have the money to get gt-40 heads at the moment because i just installed a camburg long travel kit on my truck
Old 12-21-2011, 03:26 PM
Kemicalburns
what do gt40 heads have to do with this swap??
Old 12-21-2011, 03:40 PM
Edgethis's Avatar
Edgethis
Edgethis is offline
Do what Kemical said. The 5.8 is a much more powerful motor in factory trim. You mentioned a Camburg Long travel kit ($$$), don't cheap out on the motor, when you already have to do an engine swap. The 5.8 will drop right in and bolt up, they can be had cheap too. Just search around a bit.
Old 12-21-2011, 03:45 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
what did the 5.8 that you originally suggested have to do with this swap?
oh, the same amount that gt40s have to do with it. . . .
Old 12-21-2011, 05:01 PM
pritchett's Avatar
pritchett
yeah im not doing a 5.8 swap 5.8s are hard to find and gt40 heads are expensive
Old 12-21-2011, 05:28 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
well, i dunno how deep your pockets are, but i picked mine out one of my local junkyards for 75 bucks for the set.
fireball 440
05-14-2017 05:20 PM
jb65542
03-23-2010 10:56 AM
jcarlson
2004 - 2008 F150
02-23-2008 07:32 PM
hotrodmerc
07-19-2004 09:29 PM
MikeS
03-10-2002 03:11 PM
Quick Reply: motor swap head questions
