RP Synchromax
Old 12-20-2011, 03:59 PM
Jimbob8's Avatar
Jimbob8
Jimbob8 is offline
RP Synchromax
My 04 F350 is @ 160K don't know if man.trans & axle have ever been serviced. Stoped at dealer, talked e'm into running OASIS report & asked for quote to service them $350, thanked him and left.
Don't know capacity of them, first question 6 speed & rear axle qts
Anyone know anything about this
Royal Purple® Synchromax ® Manual Transmissin Fluid
What is best for rear axle?
Jim
Old 12-21-2011, 10:18 AM
cartmanea's Avatar
cartmanea
cartmanea is offline
Rear axle takes a synthetic 75w-140 fluid. I would stay away from Royal Purple, they make their stuff thinner to get better mpgs, but it doesn't protect as well. Mobil 1 is good for gear oil, another great one is Amsoil Severe Gear, but Mobil will be easier to find.
Your transmission takes Mercon V ATF, I would go with a synthetic variant like Mobile ATF (Mercon V rated). Put the same thing in your transfer case.
Old 12-21-2011, 07:07 PM
Jimbob8's Avatar
Jimbob8
Jimbob8 is offline
Thanks, I picked up 4 qt 75-140 mobil 1, 6 oz friction modifier & synthetic gear oil silicone. 6 qt mercon V. should be good to go, anything other then
just drain & refill?
Jim
Old 12-21-2011, 07:26 PM
roadrunner01's Avatar
roadrunner01
roadrunner01 is offline
YOUR TRANSMISSION SPECS MERCON SP, which has been superceded to Mercon LV.
DO NOT use Mercon V in your Torqueshift transmission, it will eventually fail.
Your transfer case only will take 2 quarts.
Old 12-21-2011, 07:43 PM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
He said he has a manual transmission. Only the 5R110 automatic transmission requires Mercon SP.
To the OP, I believe the Mobil 1 75W-140 already has the friction modifier in it. You can try it without adding it, and if the tires chirp while making tight turns on pavement, then you need to add additional friction modifier.
Old 12-21-2011, 08:16 PM
roadrunner01
Sorry I seen that after posting, thanks for catching my error.
Old 12-21-2011, 08:29 PM
Jimbob8's Avatar
Jimbob8
Jimbob8 is offline
I'll check into that, parts guy gives it to all limited slip.
Jim
Old 12-21-2011, 08:32 PM
cartmanea's Avatar
cartmanea
Yeah, you won't need the friction modifier. Everything else sounds like you're good to go. If you do the front axle later, go with 75w-90 Mobil 1.
Old 12-21-2011, 08:52 PM
Jimbob8's Avatar
Jimbob8
Jimbob8 is offline
I can use it on my 94 F350, changing rear axle now, 437k it is so loose that sensor can't pickup for speedo, coasting gears move back then it works.
Front axle not an issue, 4 wheel drive all at rear. Thanks
Jim
whomrig
1997 - 2003 F150
05-29-2016 09:55 PM
bpounds
04-10-2010 07:52 PM
Fandini
Oil & Lubrication
13
05-31-2009 12:53 AM
PowerstrokeJunkie
10-01-2005 02:13 PM
02sd
Oil & Lubrication
09-26-2004 11:43 PM
Quick Reply: RP Synchromax
