1992 F150 will go in reverse but fights forward
I have a 92 F150, 170k 5.0l 2wd. Just dropped a new ECM in today, and noticed that the truck reverses fine however fights going forward. I'm about to take off the wheels and check this out but wanted to see if anyone had any suggestions. I tried to search the boards and didnt see this issue, If i missed it i apologize and if you could point me in that direction I would appreciate it.
E4OD Tranny. The computer shorted out and was causing the spark plugs to ignite with the key ON and wouldnt spark with key on START. It actually started smoking and pulling it out you could smell the burnt electronics. it will go forward however will fight it all the way. pushing the truck without it running causes the tires to skid and not roll. Reverse is fine both running and pushing.
Park brake has tendency hold tight from moving forward but not so good or at all in reverse.
kiohio1985
11-10-2006 05:51 PM
