1996 f150 problem
Old Sep 8, 2008 | 11:36 PM
frydaddy56's Avatar
frydaddy56
1996 f150 problem
I have a 1996 f150 that when you put it in reverse it goes into reverse real hard then feels like something is bound up and slipping it doesn't do it allthe time when you drive in the forward gears it drives and shifts like it should i know the u joints need replaced but i think it more than them, could it be in the rear end a buddy of mine said it could be the pinon shaft any help would be appreciated
Old Sep 9, 2008 | 08:12 AM
guitarnik's Avatar
guitarnik
my old 91 f150 e4od did this forever, nobody could ever tell me what would cause it. no tranny shops could figure it out. they all said it had to be rebuilt, but i didnt do that and it never fell apart...... soo i dunno, changing my fluid and filter helped some but thats all i tried.
Old Sep 13, 2008 | 10:03 PM
frydaddy56's Avatar
frydaddy56
problem found hopefully !
took the rear drivers side brake off and what was left of the pads fell out in junks and was steel to steel i think it exploded , when in reverse i would apply the brake before shifting into reverse and smaashing the exploded pad against the drum then when i let off the brake to move in reverse it was grinding up the left over pad , other side break ok changed both now everything seems to be ok
