mazda transmission help
Old 12-17-2011, 11:45 AM
ryan f150 4x4's Avatar
ryan f150 4x4
ryan f150 4x4 is offline
dose anyone know if i can put a new say 97 to 99 5speed transmission in my 92 as my mazda transmisson has no 1 or 2ed gear and i cant find a mazda anywhere around here
Old 12-17-2011, 12:13 PM
f-trucker88's Avatar
f-trucker88
f-trucker88 is offline
im not sure what kind of vehicle u have but assuming u have an f150 with a m5od trans im gonna say yes u can
Old 12-17-2011, 12:14 PM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
Yes, and no...
Yes-The transmissions are the same...
No-The bellhousings/bolt patterns are different....
ANY small block ford (300, 302, 351w) will bolt right up....Only issues will be cross member/driveline....
Old 12-17-2011, 12:23 PM
f-trucker88
then he could use the old bell housing assuming its in good shape? is that correct?
Old 12-17-2011, 12:28 PM
SideWinder4.9l
Uhhh.....That's a hard one to explain...
The Maza M5OD's use a integrated bellhousing/transmission body...
So no....And the engine swap is just too much $$$ for the hassle....
Old 12-17-2011, 12:45 PM
f-trucker88
ahh ok sorry i was unaware of that fact thanks
Old 12-19-2011, 03:43 PM
ryan f150 4x4
thanks for the help i final found one she ba good as new after i get the new trans in
Old 12-21-2011, 12:54 PM
tazzerblue's Avatar
tazzerblue
tazzerblue is offline
Are you looking for the Mazda 5 spd? I'm swapping out the mazda in my truck 1989 f-250 light duty 5.0 5spd would sell as a pkg, is leaking a little at rear seal. has 78k on, looking for ZF for the 460 I'm installing. Located SW Minnesota.call if interested, truck still running, just putting together the equipment needed to do install.five zero seven, eight 2 eight, sixty, eight, sixty
Old 12-21-2011, 02:07 PM
SideWinder4.9l
Might I suggest pm-ing phone numbers, addresses, etc....
So you won't have a lotta random calls, etc....and for safety...
Old 12-22-2011, 07:00 PM
f-trucker88
this guy is a jenious lol
Suedekustom
13
10-29-2008 02:57 PM
flatlander2270
10-22-2007 07:42 AM
sckootter578
09-27-2007 09:42 PM
Brian79150
01-12-2004 07:07 AM
92F150XLT4*4
05-21-2003 04:14 PM
Quick Reply: mazda transmission help
