speedo after sas ?
If you swapped the rear axle to a 9 inch Ford you removed the VSS, that's what drives the speedometer.. The easy way would be put the 8.8 back in there with the correct gears to match the front axle.. Since you don't have provisions on the '95 transmission either. There are adapters and such ( the ones I've seen mount by the yoke on the rear diff) but best I remember it runs into $$$..
did'nt think the adapter would be too costly($$$) if you could come up with the name of the company(s) that offer the adapt. the guy we did the swap for would consider buying one, if not ,we will take your advice and the original rear end will go back in with the matching gears. thanks for the info.
Received 3,181 Likes
on
BRay09
23
07-06-2011 09:15 PM
Tdvjensen
04-13-2006 11:31 AM
donnor
15
12-31-2004 08:00 AM
