pressure and return hose on steering gear...help please
Old 12-11-2011, 07:49 AM
earthquake68's Avatar
earthquake68
earthquake68 is offline
Originally Posted by Blue and White
You might as well nip the steel line off just above the fitting with a bolt cutter. You'll be getting new hoses - which is a good idea anyhow with a new gear. They can rot from the inside. You might get a socket over the nut then and get it off. At least you'll have more room to work.
If not, I've used a small pipe wrench on stripped tube nuts successfully.
I thought about the socket idea too, but the tube goes up from the bottom and I'm not sure there's enough room to get a socket in there. The pliers I showed have a narrower profile than a pipe wrench, but work the same way.
....I'm not trying to sell tools here, but if you buy a set of those Knipex pliers or the Channel locks, you'll be amazed at how they work and wonder why you didn't buy them before. They saved my butt a few times.
Old 12-11-2011, 03:03 PM
mark a.'s Avatar
mark a.
mark a. is offline
Why not just remove them from the pump and then take the box off. Then you can try to salvage them after it's out.
Old 12-11-2011, 04:15 PM
gabe911's Avatar
gabe911
gabe911 is offline
Finally got them off, thanks for all yous help...you know what Im humble & man enough too admit I stupid...I was turing the wrong way the whole time! SOB..anyways they're off and about to put the new one on...Reading in Chiltons it says to fill with gear oil when done..is that correct with a P/S gear box? My truck is sometimes hard to look up on there b/c originally it was a f100 2wd 302 manual steering...the PO basically installed and modified it to a F150 4 wheel drive p/s...
Old 12-11-2011, 07:43 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
Gear oil is NOT correct for PS. Manual steering, the gearbox is filled with gear oil.
PS uses ATF or PS fluid (ATF was the factory fluid).
randyj68
06-29-2014 07:53 PM
tbugher62
06-05-2013 10:20 AM
MrBevo
16
06-03-2010 09:48 PM
1Saint
13
11-11-2009 04:36 PM
tenptbuck7mmmag
03-09-2006 08:40 AM
Quick Reply: pressure and return hose on steering gear...help please
