First time headers on a 65 4wd with FE
Old 12-10-2011, 04:34 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
I have not installed headers on a 4wd drive before. My Question is is this to close to the front drive line? If so and you had this problem what was your cure? Im thinking cut the collector and put a 45 degree bend with the flange away from the drive shaft.
Old 12-10-2011, 05:35 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,645 Likes on 1,341 Posts
Way too close.....Your idea to cut it and put a 45 in there is probably as good an idea as any.
Old 12-10-2011, 06:37 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
I was afraid thats what I was going to hear. Da*n at least Im not hurt to bad. The headers were only about $165 from Jegs not including shipping. Have to see if the exhaust shop guy can rescue me. If not any suggestions Im open at this point.
Old 12-10-2011, 07:25 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
How close are they near the 4-1 merge? Might be ok with cutting off the collectors and having the exhaust shop make new pipe coming from the merge, and use a more conventional (and thicker) flange. That would reduce the possibility of the collector gaskets causing leak issues...... One of my main pet-peeves with most headers, cheap collector flanges that repeatedly leak, due to flexing/bending.
Old 12-11-2011, 04:56 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
That could be a plan Ill talk about that with the exhaust guy if he is stumped. Thanks for the heads up R_W.
Wopstar
01-30-2009 11:35 AM
Daddyoisback
03-18-2008 07:38 AM
iceman320
01-02-2006 01:30 PM
zachsherman88
17
07-04-2005 10:12 PM
snagmaster86
Exhaust Systems
02-18-2005 07:56 PM
Quick Reply: First time headers on a 65 4wd with FE
