headers
Old Jan 1, 2006 | 10:49 AM
iceman320's Avatar
iceman320
headers
I have a 78 f-150 2WD with the 351M. and I want to put some exhaust headers on it but I can't find any headers for the 2wd model so I wanted to know if the headers for the 4wd model will fit on my 2wd truck. I want some headers that have a 3" collector. thanks
Old Jan 1, 2006 | 11:59 AM
LxMan1's Avatar
LxMan1
Try Dynomax, they had headers for my 77 with a 460. I think the 4wd headers will hit and not fit.
Old Jan 1, 2006 | 12:20 PM
MBBFord's Avatar
MBBFord
You can try summit racings headers, but they might be for a 4wd.
Dynomax would also be a good place to look along with headman and possibly hooker.
I think they all sell headers with 3" collectors.
Old Jan 1, 2006 | 01:04 PM
iceman320's Avatar
iceman320
headman only have headers for the 4wd model I have looked at them but I will look at the others. my boss at work told me that the headers for the 4wd models would fit on the 2wd models but not the other way around.
Old Jan 1, 2006 | 01:20 PM
iceman320's Avatar
iceman320
ok nobody has the headers for a 2wd 78 ford f-150 so this stinks unless some headers form a different year of truck will fit on mine. going to check out the summit racing headers next I will get back to you guys. ok just checked out the summit shorty headers but they are for a 86 ford bronco with a 351 windsor would they work or not?
Old Jan 1, 2006 | 05:20 PM
74 F100 351m's Avatar
74 F100 351m
I got my set of headmans from O'reilly's for 125.00. 1 3/4 head pipe and 3" collectors
Old Jan 1, 2006 | 05:37 PM
iceman320's Avatar
iceman320
ok guys I found a set of hedman hedders for my truck that fit the 2wd model so I guess i will maybe order them their 149.99 so that's not to bad alot better then the 299 that lmc truck wants anyway. now I just have to decide what mufflers i'm going to use?
Old Jan 1, 2006 | 09:26 PM
74 F100 351m
I went with 2 1/2 " pipe and 12" glasspacks. Real loud at 5000 rpm. Have photos where it comes under the frame to the outside of the frame in gallery.
Old Jan 1, 2006 | 10:18 PM
MBBFord's Avatar
MBBFord
Wow, you like to rev that 351M there huh.?.
My 400 is loud enough at idle(900 rpm)no pipes!, and my 302 is real loud at 2,000 rpm + with the same exhaust set up as yours.
Old Jan 1, 2006 | 10:54 PM
MBBFord's Avatar
MBBFord
Iceman320, there is a set of headman headers going on ebay right now for $100 with one bid and they are for your truck 2wd. With a little less than 2 days left, those would be almost perfect for you.
Item number: 8025757560
Old Jan 2, 2006 | 01:30 PM
460me's Avatar
460me
Try Doug Thorly.a little on the $$$ side but worth it.I have a set on my 79 2wd and I am very happy with them.......
