1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
HEELPPP IM STUCK!
Old 12-05-2011, 10:05 AM
62_F250's Avatar
62_F250
62_F250 is offline
HEELPPP IM STUCK!
how do you remove dust/grease cap on hub. there are small tapered nuts holding it on. they are around each stud. ive managed to bang out two somehow but te rest wont budge and they keep bending and breaking (the metal nuts) any tricks or tips plzzzzz
Old 12-05-2011, 11:47 AM
garbz2's Avatar
garbz2
garbz2 is offline
I assumed on the other thread that you meant the drum retainers.
I am assuming you are asking about the tapered retainers under the hub nuts to center the axle hub on the studs?
I have used a section of 3/4" schedule 40 pipe slid over the stud and a sharp rap with a 3# engineers to jostle them loose. It sounds like corrosion has seized them. Spray them with a good penetrating oil like Kroil or Gibbs and let the fluid work. After a bit use a propane torch and apply some heat to the studs to help brake them loose.
If you are bending and breaking things you may already have damaged the axle flange.
Kroil Google Deal
Gibbs GIBBS Ultra, Mega Penetrating Lubricating Oil
Garbz
enikolich
11-03-2017 11:37 AM
Matther777
1947 and Older Ford Trucks
03-14-2015 10:45 PM
jawdoc
1999 to 2016 Super Duty
07-18-2011 11:28 AM
Steely Dan
Escape & Escape Hybrid
06-14-2004 01:16 PM
7855F100
09-08-2001 10:54 PM
Quick Reply: HEELPPP IM STUCK!
