2000 excursion wont start..Help!!!
Old 11-26-2011, 10:16 AM
fordgirl2000's Avatar
fordgirl2000
fordgirl2000 is offline
I have 00 excursion (automatic) and it wants to start but doesn't crank...I. checked the starter, battery, solenoid, codes, key and it still won't crank. Any suggestions???
Old 11-26-2011, 12:45 PM
809taino's Avatar
809taino
809taino is offline
More info please..
How did you check the battery, starter and solenoid?
What does your battery gage do when you turn the key?
What do you mean by "wants to start"?
What sounds do you hear when you turn the key?
Do you have a crazy x-boyfriend?
Old 11-26-2011, 01:55 PM
fordgirl2000
At autozone, also like four diff people came to look at it and tested the codes, the key,
Sorry not to good with terms but it just sounds like its going to start but doesn't actualy fre up...don't know how else to explain it...kinda like it needs a jump...tried that to and it ddidnt work...no crazy ex here..lol
Old 11-26-2011, 02:17 PM
Daz00Excursion's Avatar
Daz00Excursion
Daz00Excursion is offline
My Backpack Gots Jets
sounds like fuel pump. have someone go under the truck and tap on the gas tank a few times. then try to start it again. if its safe have them tap on the tank while your trying to crank it over.
Old 11-26-2011, 03:06 PM
Front Runner's Avatar
Front Runner
Front Runner is offline
Make sure that your fuel shut off switch/button has not been activated.
Go to the fuel tank, take the gas cap off and have someone cycle the key to the "on" position, but do not attempt to crank it up.
Put your ear closer to the gas filler opening and listen to the fuel pump come on when the key is cycled. It makes a swirling noise that you can hear through the opening.
No noise? Fuel pump not working.
Old 11-26-2011, 03:09 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
It would help to know what kind of engine you have too, gas or diesel. It makes a huge difference in troubleshooting.
Stewart
Old 11-26-2011, 03:13 PM
fordgirl2000
Its gas....v8 5.4l...had the fuel pump checked already, its working...where's the fuel on switch???
Old 11-27-2011, 08:05 AM
subford's Avatar
subford
subford is offline
Is the engine cranking very slow even with a jump?
If yes it would not be a fuel problem.
If yes you have a bad ground, cables, battery connection or a bad starter.
Old 11-27-2011, 08:14 AM
fordgirl2000
Its not the fuel pump, I checked the cables an starter they all work...it woi asked for thedtr n't start even with ajump..I'm dumbfounded????I also ased for a dtr sensor but they couldn't find it at autozone??
Old 11-27-2011, 09:24 AM
subford's Avatar
subford
subford is offline
Well if it is cranking (engine turning) the DTR sensor is OK.
How fast is it cranking when it will not start?
If it cranks normal then we can look at why it is not starting.
Do not know why the parts store did not know what a DTR sensor was, maybe it is a dealer only part. But if it is cranking at all forget the DTR sensor.
Old 11-27-2011, 09:43 AM
fordgirl2000
It does crank up but won't start- again I apologize for my wordage- it will rank as foras long as I turn the key, but won't start I acceleraten nothing, not even with a jump start???
Old 11-27-2011, 10:35 AM
subford's Avatar
subford
subford is offline
You say you have no codes but it will crank but will not start.
Turn on the key and see if the fuel pump will run and shut off.
If it does get a set of NOID lights.
Unplug a COP and an injector.
Plug a NOID light into the plug for the COP you unplugged.
Crank the engine and see if the NOID light flashes.
If it does then plug a NOID light into an injector plug and crank the engine and see if the NOID light flashes.
Let us know what you find.
Any auto part store should sell or rent NOID lights.
A NOID light:
Old 11-27-2011, 05:29 PM
809taino's Avatar
809taino
809taino is offline
You might wanna check your spark plugs also. Sounds like your not getting fire. if your engine turns over but doesn't ignite then this can be a series of things. I would start at the spark plugs. While it's cranking, Do you get that moment when it fires? or does it just crank?
No ex-boyfriend? Does your husband got a crazy baby-mama?
Old 11-27-2011, 11:05 PM
jh818's Avatar
jh818
jh818 is offline
Maybe check your camshaft position sensor (CPS). Also the connector to it to make sure it's making contact.
Old 11-28-2011, 12:42 PM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
Hmmm....probably a long shot, but when cranking, try stepping on the gas and see if it starts.
If it does, replace the IAC and that will fix your problem.
Quick Reply: 2000 excursion wont start..Help!!!
