How to install anti rattle
I'm thinking of installing new exterior anti-rattle rubber on the newer doors I plan to install. Can they be installed without taking out the door glass? From the picture it looks like a friction fit clip in (the green tabs) moulded or stapled into the rubber. Does anyone know if the replacements from LMC fit the same way?
[IMG][/IMG]
[IMG][/IMG]
how to install anti rattle clip
I replaced my exterior window trim without removing the glass all i did was pry up one side of the old window trim and pulled it right out. Then pushed the new one in place. I don't think you would be able to reuse the old ones anyway,because mine bent up with the method i used.
PapaBearYuma
10-27-2016 01:53 PM
Kurtboyd
09-12-2015 03:01 PM
wavetrain75
04-02-2013 03:42 PM
joezzz
33
05-21-2011 01:23 AM
1994, 2004, 87, anti, antirattle, channel, expedition, f150, ford, install, installing, rattle, spring, window, winow
