1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
99 navigator wont start. theft light.
Old 11-12-2011, 06:24 PM
phinfan1016's Avatar
phinfan1016
phinfan1016 is offline
Wife went to start the car this morning. Would not fire. Engine cranks. Theft light goes off after three seconds with key in the ignition. Take the key out and the theft light blinks every two seconds. Tried multiple keys. None work. Made sure only one key on key chain. Keyless entry still works. Fobs still work. Tried disconnecting battery. Everything I am.reading says I will have to tow it to a dealer. Cant pull codes. Any ideas?
99 navigator 4x4 5.4 sohc
Thanks
Nick
Old 11-12-2011, 07:56 PM
Boat Tug's Avatar
Boat Tug
Boat Tug is offline
If your '98-'00 Expi/Navi has the Ford System 3 (or 4) Security System the following applies:
It has a small red light (Valet Button) below the steering wheel, sort of between your knees. Look directly behind that little red light on it's wire loom that goes up under the dash, there is a very small Micro 'Emergency Override Button' about 3" behind the Valet Button on the loom. You'll need a flashlight.
When you find it, insert the key and turn on the ignition so all the dash lights are on - then push the Override Button, the Security System should now be disabled and the car should start.
You may have to hold down the Override Button while cranking the engine over.
You can re-set this entire system too.
To re-initialize Ford System 3 (or 4) Alarm System:
Disconnect the battery.
Wait 2 minutes for the module to lose all traces of voltage.
Turn the ignition key to the RUN position.
Reconnect the battery.
Shut the key OFF and press LOCK on the drivers door switch.
Done.
The system should work correctly. If it doesn't then a part of the system has failed.
Old 11-13-2011, 08:35 AM
phinfan1016
Thanks boattug. I'll try that when i get home.
Old 11-13-2011, 01:26 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
There's nothing wrong with the PATS side of things.
If you don't have the extra system Boat Tug described (never have seen one...), you're left to check the basics like air, spark, and fuel.
Old 11-13-2011, 02:35 PM
phinfan1016
Thanks projectsho89. I tried the reset by disconnecting the battery. obviously if it isnt a pats problem that wont help. Check fuse for fuel pump. Have 12 volts on both sides. Swapped relay. No change. I suspect that the fuel pump let go.
Old 11-16-2011, 04:19 PM
phinfan1016
Ok. So i fooled around with it a few days. I dont have a fuel gauge or a box to pull codes. So, i had it towed to the shop. The car fired right up. BEFORE it was hooked to the tow truck. Intermittant problem. Bad spot on the fuel pump motor? Who knows.
Old 11-17-2011, 03:50 AM
omegalita's Avatar
omegalita
omegalita is offline
Swissnavigator
Could be the crankshaft position sensor...? Or the battery is to low to unlock the anti-theft-system...
Old 12-14-2011, 06:22 PM
phinfan1016
Just an update. The fuel pump went bad. No warning. After enough tries it would run again for a few days. My guess is the
fuel pump motor had a dead spot.
Old 12-14-2011, 08:20 PM
pdqford's Avatar
pdqford
pdqford is offline
Thanks You for reporting back what the solution was - it will help someone out when they use the search function.
Old 08-13-2012, 03:12 AM
serrat082's Avatar
serrat082
serrat082 is offline
98 theft light issues.please help
hiim having issues.please help im going to make short. i try abrithing you see online nothing work.i change the key transponder no luck change the theft module no luck hcang the ecc module no luck change the stupid computer no luck reprogram the keys like 3 times all was done.still same problem.can anyone help.what im missing.all the parts ae working condition and all the numbers match.
Old 05-19-2016, 10:07 AM
islandsoft's Avatar
islandsoft
islandsoft is offline
steering column
I have had this problem for years++.
When I do:
1. Lower the steering column all the way possible.
2. make sure the shifter is all the way left, hard into park.
try. it works for me, maybe you. but I have no explanation.
Old 05-19-2016, 12:33 PM
Action410's Avatar
Action410
Action410 is offline
WOW as long as you don't have to stand on your head ......
Sounds crazy Nick however you don't have much to loose.
>>>>>>>>Action
cardc26
09-18-2012 05:04 PM
Ranger354
1997 - 2003 F150
24
12-07-2006 06:01 PM
muskie770
1999 to 2016 Super Duty
01-03-2005 02:22 PM
Peter Greenlund
08-31-2004 02:13 PM
DIV16
11-08-2002 07:03 PM
Quick Reply: 99 navigator wont start. theft light.
