What engines do I have? 351C, 351W or 351M/400
Old 11-09-2011, 07:43 PM
skyrader's Avatar
skyrader
skyrader is offline
Trying to figure out what engines are in 2 parts trucks recently acquired. One has a 'rib' if you will in the casting and the other doesn't. The one with the 'rib' seems to be identical to the 400 block in my 80 F360. The other engine doesn't have the 'rib' I have pics of both these in my albums. What I have gathered so far is neither are 351W. I am wondering if maybe the engine in the green truck (see album) is a FE 360. Vin for this truck shows it had a 360 originally. person I bought it from said the engine was replaced with a 360 however she wasnt sure and the air cleaner has a 351 emblem on it so Im not sure what I have. Both have 8 bolt valve covers and vertical fuel pump bolt patterns so the 351W is out. I was told by the seller the engine with the 'rib' was a 351W but it deffinately appears not to be that.
Can anyone help me identify these two engines? Both run good, the green truck has a stock intake w/2bbl carb, the one with the 'rib' has an Edelbrock intake and Edelbrock 4bbl carb. I don't need either engine but might want to keep the Cleveland if one is a Cleveland. I just want to be able to sell either as what they are not what former owners said they were.
Any help would be greatly appreciated.
Old 11-09-2011, 08:49 PM
crsmiffy's Avatar
crsmiffy
crsmiffy is offline
Looks like a cleveland to me, But I am not familiar with the FE360. The width and the rib would suggest a 351m-400 as against a 351C. I have some photos in my albums. Have a look for comparison.
Old 11-10-2011, 12:07 AM
85e150's Avatar
85e150
85e150 is online now
Received 1,647 Likes on 1,343 Posts
8 valve cover bolts = 335 series, so no 351w.
351c is going to be over 1" narrower at the intake than the 351m/400.
351m/400 pic and info:
351M/400 Performance Build Up
351C, note difference in height from water pump
http://www.bierbros.net/images/graphics/351cshortrs.jpg
Old 11-10-2011, 04:47 PM
skyrader's Avatar
skyrader
skyrader is offline
not sure what you mean 'difference in height from water pump. I see the pic but height from where to where?
Old 11-10-2011, 10:24 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Old 11-11-2011, 01:29 AM
skyrader's Avatar
skyrader
skyrader is offline
Ahhhhhh! gotcha ok thanks ctubutis
Eli1644
03-03-2014 04:55 PM
krasmussen
04-09-2007 09:38 AM
scotttruck
01-12-2005 05:35 PM
ExcellentRed
08-09-2004 05:10 PM
carp1
08-08-2001 10:58 PM
Quick Reply: What engines do I have? 351C, 351W or 351M/400
