Hoping to install remote start myself...need help!
#46
Ok the mental picture just hit me now. I'm doing that kinda similar to how I did my door locks. So for the other outputs...the 2 ignitions and the accessory...are they tapped or how will I make those connections? Those are the only other connections right? The other 12V inputs I can just hook to my fuse block right?
#48
Perfect timing. I'm wiring it up right now but have one last question...the remote start relay only has one accessory output, but the wiring diagram for my truck from bulldog security is showing I have two wires, one labeled "Accessory/Heater Blower 1" and another labeled "Accessory/Heater Blower 2". So basically I have 2 accessory wires on my truck and only 1 on my remote start.
#50
#51
i know this is a super old thread but im at the same point in my install as this fellow at the end of this thread i have the same question as he did in the last post "the remote start relay only has one accessory output, but the wiring diagram for my truck from bulldog security is showing I have two wires, one labeled "Accessory/Heater Blower 1" and another labeled "Accessory/Heater Blower 2". So basically I have 2 accessory wires on my truck and only 1 on my remote start." i bassicly have the same problam as to not knowing what acc wire to use on the truck any feed back will be welcomed
#52
Not sure if you've figured this out yet.
I used the single RS output to control 2 relays, each powering one of the ACC wires. That way I was able to power both without worrying about overloading the output on the RS.
It's possible that the single RS output has enough juice to power both but I figure they're separate for a reason & didn't want to join them.
Bryan Hagan
12-19-2015 07:50 PM
86fn150
16
10-15-2014 10:05 AM
The Fool On Th Hill
04-11-2012 12:47 PM
kaynan
01-23-2006 02:22 PM
