Hoping to install remote start myself...need help!
  #46
Old 11-13-2011, 02:12 AM
AndeyHall's Avatar
AndeyHall
AndeyHall is offline
Originally Posted by boulderguy
The starter wire gets cut & split between those two RS wires. Cut it about 3" from the ignition harness.
Ok the mental picture just hit me now. I'm doing that kinda similar to how I did my door locks. So for the other outputs...the 2 ignitions and the accessory...are they tapped or how will I make those connections? Those are the only other connections right? The other 12V inputs I can just hook to my fuse block right?
  #47
Old 11-13-2011, 11:58 AM
boulderguy's Avatar
boulderguy
boulderguy is offline
Yep. The others just tap into the existing wires, worm them thru & tape them up - don't cut them. The video shows this pretty well. All the B+ inputs go to fuse block.
  #48
Old 11-13-2011, 12:15 PM
AndeyHall's Avatar
AndeyHall
Perfect timing. I'm wiring it up right now but have one last question...the remote start relay only has one accessory output, but the wiring diagram for my truck from bulldog security is showing I have two wires, one labeled "Accessory/Heater Blower 1" and another labeled "Accessory/Heater Blower 2". So basically I have 2 accessory wires on my truck and only 1 on my remote start.
  #49
Old 11-13-2011, 12:25 PM
boulderguy's Avatar
boulderguy
pop-quiz - do these need relays?
  #50
Old 11-13-2011, 12:52 PM
AndeyHall's Avatar
AndeyHall
No. But the one im confused about is on the other side of the ignition relay from those wires.
  #51
Old 12-25-2013, 11:01 PM
WVmountainman07's Avatar
WVmountainman07
WVmountainman07 is offline
i know this is a super old thread but im at the same point in my install as this fellow at the end of this thread i have the same question as he did in the last post "the remote start relay only has one accessory output, but the wiring diagram for my truck from bulldog security is showing I have two wires, one labeled "Accessory/Heater Blower 1" and another labeled "Accessory/Heater Blower 2". So basically I have 2 accessory wires on my truck and only 1 on my remote start." i bassicly have the same problam as to not knowing what acc wire to use on the truck any feed back will be welcomed
  #52
Old 01-06-2014, 10:48 AM
boulderguy's Avatar
boulderguy
Not sure if you've figured this out yet.
I used the single RS output to control 2 relays, each powering one of the ACC wires. That way I was able to power both without worrying about overloading the output on the RS.
It's possible that the single RS output has enough juice to power both but I figure they're separate for a reason & didn't want to join them.
  #53
Old 01-06-2014, 11:19 PM
WVmountainman07
i ended up using just the grey yellow wire and it worked fine
63bird390
1999 to 2016 Super Duty
12-21-2017 11:18 AM
Bryan Hagan
12-19-2015 07:50 PM
86fn150
16
10-15-2014 10:05 AM
The Fool On Th Hill
04-11-2012 12:47 PM
kaynan
01-23-2006 02:22 PM
Quick Reply: Hoping to install remote start myself...need help!
