1986 F150 Ignition wire
Old Jan 23, 2006 | 12:18 PM
kaynan's Avatar
kaynan
I am in the process of installing a remote starter into my truck. I am having trouble finding the ignition wire(s). I have tested every wire coming out of the steering column but none of them seem to be ignition. According to my instructions the test light needs to stay on when I am cranking the engine over and all the wires I have found the light goes out.
Am I looking in the right place for the ignition wires? Please help, also what color am I looking for?
Old Jan 23, 2006 | 02:12 PM
pknute's Avatar
pknute
An ignition wire goes to the starter relay when you turn the switch to start. Another ignition wire goes to the battery terminal on the coil providing full current at start and reduced current (1.1 ohm resistor) in run position.
Old Jan 23, 2006 | 02:16 PM
kaynan's Avatar
kaynan
Do you know what color they are? So was I looking in the wrong bunch of wires? I was looking where they come out of the steering column. Where is the starter relay located?
Old Jan 23, 2006 | 02:22 PM
pknute's Avatar
pknute
Starter relay is located on the passsenger side fender well near the battery. I don't have an 86 wiring diagram, but in 1980, the ignition wire to the starter relay is R/LB and the ignition to coil is BR/PK.
RangerDude17
Jan 25, 2014 04:38 PM
Hogtrapper
Mar 13, 2013 08:53 PM
boulderbronco
Dec 12, 2007 06:12 PM
airharley
Electrical Systems/Wiring
Sep 1, 2007 08:11 AM
doubleh
Jan 16, 2007 12:43 PM
