installing body lift problems!
im installing a 3" body lift on my 1995 f-150. i did the bed fine and now that it was time to do the cab i cant get any of the bolts to budge and the front two bolts jsut spin cause the radiator support is rotted out. does anyone have any tips or tricks that can help me out with getting the cab done?
thanks,
Bill
thanks,
Bill
thanks,
Bill
thanks,
Bill
Hey Bill, I just did a 3" body lift on my truck a couple weeks ago. I had no problem with the front 2 as I had my radiator support + the 2 front bushings and bolts all replaced so those came out fine.. but as for the 4 cab bolts, I used my 4.5" grinder to cut the bolts off from the underside and popped them through the top. If you don't want to go to that extent like I did, then use some PB Blaster to try and free up the bolts.
By the way how did the bed go for you? I had to grind all 6 of my bed bolts off cause they were so rusty I couldn't get them to move.
Yeah when I cut my cab bolts off I had to cut the nut off too. so you're going to need to get some new nuts to fit on the body lift kit bolts because the kit doesn't come with any. (They expect you to re-use the factory Ford nuts) So I brought my 4 cab bolts into Fastenal and they hooked me up with some lock nuts for them.
GearJaminOutlaw
03-09-2009 02:10 AM
RockWVU
02-26-2008 08:16 PM
