solenoid pack
on
Muekstar - I'm confused with Step 3 and 4, testing pins 1 and 4. Step 3 says on/off and step 4 PWM. Am I testing the same pins ??? I hope i'm making sense
one more question, You think i would need to remove the solenoid pack to test or can I just test while its still installed
It is pretty difficult to access the connection. If you had a pigtail from a donor vehicle, it could be done more easily while installed.
on
You can get a new pigtail from Ford for around $40. Ford# 3U2Z-14S411-VCA
Motorcraft# WPT-590
It can also be purchased here. E40D 4R100 transmission wire harness Ford transmission solenoid harness
There are also a few listed on ebay. ford econoline suspension | eBay
Motorcraft# WPT-590
sccamper
11-19-2017 12:11 PM
uncleben77
04-09-2014 10:39 PM
beerdude41867
01-07-2013 03:24 PM
calisdad
12-27-2011 10:17 AM
