so i am in the process of putting back together my 96 f150 4x4 and i was trying to re-attach the steering shaft to the power steering pump but it was going on as easily as i thought. do i have the hammer it on or should the shaft just slide over the pump nice and easily. i dont want to ruin anything.
You need to line the splines up properly but just tapping it wont mess them up. It should slide on pretty easy, but i think it may need a little help with the hammer.
well i just tried to put it on and there is no give on it. think i should throw some heat on the shaft to help it slide on or should i pry on the end of the shaft to open up the hole a bit??
