new injector startup
First before injector install you make sure you suck excess oil out of cylinders.
If you are worred, pull the GPS after you install the injectors, then you pull a fuse or 2 and a relay and you can crank the motor over blowing the rest of the oil out though the GP holes. (be sure to temp secure the valve covers before doing this)
Then, just crank for 10 seconds at a time giving the starter a break to cool off, eventually it will start, and run crappy.
It will start crappy for a while as well due to air in the system.
I always install the injectors, leave them unplugged. Remove the glow plugs and put the valve covers back in place, put a bolt in the top and bottom of them. Then bump the starter over to make sure it isn't hydrolocked. Then crank on it for a few seconds to get all the fluid out of the cylinder. Then put your glow plugs back in, hook up all the connectors, install vc's and start cranking...
Yep, I'm with James. The two times I've had my injectors out I put the injectors back in, remove the glowplugs, put the valve cover back on with a couple bolts finger tight, bump the starter a couple times, then put everything back together.
Then crank, and crank, and crank... for a long time (just don't overheat the starter, give it a break every 30 seconds or so). And be prepared to keep the idle up for a minute or two, and there will probably be a lot of smoke at first.
joker67735
09-12-2013 09:28 AM
MustangMatt96GT
34
11-14-2009 10:43 PM
