02 explorer 4.0 sohc engine help!!!
Old 10-22-2011, 11:57 AM
f2504x4man's Avatar
f2504x4man
f2504x4man is offline
I searched around for a few hours and couldnt find any information on this. Have an 02 (10/01) explorer 4x4 w/ 4.0 sohc vin e. My repair info says I can remove the heads without pulling the engine. Two dealers said I have to remove the engine but I can't find that any where else in any repair info. Timing chain appears to be in the rear. Anyone know? Does a plastic plenum make a difference? Thanks in advance!
Old 10-23-2011, 07:43 AM
ncranchero's Avatar
ncranchero
ncranchero is offline
I've never heard of anyone being able to replace the rear timing chains without removing the engine. There is a front and rear set.
Old 10-23-2011, 05:47 PM
f2504x4man's Avatar
f2504x4man
Do you know where I can find a diagram on the rear timing chain? I have alldata and it says nothing about a rear chain or removing the engine to remove the heads.
Old 10-23-2011, 06:10 PM
ncranchero's Avatar
ncranchero
Send me your email address in a private message.
If your Alldata Index reads like the Ford manual Index then it lists the "Timing Drive Components —Camshaft Drive Cassette, LH " under the " In-Vehicle Repair" topic. It doesn't list the RH because it is not an "In Vehicle" repair procedure. It kind of had me stumped there for a minute until I realized what "Section" I was looking at.
The Chilton reads:
PATH: Engine Mechanical > Engine Mechanical Components > Timing Chain Cover, Chain, Sprockets, & Seal > Removal & Installation > 4.0L Engine > SOHC Engine (VIN E)
SOHC Engine (VIN E)
1.Before servicing the vehicle, please familiarize yourself with safety procedures.
2.Drain the engine oil.
3.Remove or disconnect the following:
*Negative battery cable
* Engine from the vehicle
*Oil pan
*Engine front cover
*Cylinder heads
Ford manual STILL says you can R&R the right cylinder head IN THE VEHICLE though .......... IDK !!!!
READ , AND
Old 10-27-2011, 11:46 AM
f2504x4man's Avatar
f2504x4man
Just as a follow up. I still could not find the info on alldata. I did have to remove the engine as you confirmed. Thanks for your help.
Stephen Yarych
03-06-2013 01:03 PM
LWolffe
06-03-2010 05:52 PM
chiva06
04-30-2009 10:22 AM
rocker_topper
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
09-05-2007 11:15 PM
69401
06-11-2007 09:49 AM
Quick Reply: 02 explorer 4.0 sohc engine help!!!
