2006 150 FX4 5.4 oil capacity?
Hey guys today or tomorrow im gonna change the oil for the first time in this truck. It has 34000 miles and it has been changed every 3000 miles but we just bought the truck so this will be the first time i have changed it. Any thing to look out for? tips,tricks? What filter should I use? And how much oil does the motor hold?
7 quarts is the capacity
Use the Motorcraft FL820 filter as it has a better anti-drain back valve.
5w-20 is the recommended oil and any good semi-syn blend should be sufficient, Motorcraft works quite well.
EDIT: FYI, most Walmarts carry the Motorcraft filters and oil.
silverfrost99
2004 - 2008 F150
39
04-14-2006 05:05 AM
