Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 10-19-2011, 09:23 PM
62unibeastie 62unibeastie is offline
Garage is empty, add now
62unibeastie is starting off with a positive reputation.
Dash Wiring
Hi, I'm new to the Forum and this is my first post. I like what I see so far, you guys seem great.
I've got a 62 Unibody with a 223, and 4 on the floor, its my first Classic and I got her about a year ago. I love the old gal. My problem is Wiring It looks like the Former owner had a party under the dash and left me a mess. I want to rewire it. dash lights dont work, the heater is DOA, the cigarette lighter has no juice... Its just ugly.
My question is, is there anybody who sells complete wiring harnesses with the right connectors and such already in place, or am I gonna have to go it alone.
Thanks for any help you can give a n00b getting his feet wet in the truck world.
  #2 (permalink)
Old 10-20-2011, 02:19 PM
Scout Pilot's Avatar
Scout Pilot Scout Pilot is offline
1962 Ford F-100
Scout Pilot is starting off with a positive reputation.
That is tough one. If you just run wires by yourself, you can cusomize it alittle bit more and you learn more about what is under dash. On the other hand, simplicity is always attractive. I stuck my head under my dash and I saw more splices than I cared to mess with. I am just going to replace wire by wire since I only have about a dozon to mess with.
  #3 (permalink)
Old 10-20-2011, 02:54 PM
Thanks for the reply. I was kinda thinkin the same thing, wire by wire might teach me a thing or two. Does anybody have any suggestions for some kind of idiot book to make the job a little easier. I've got a little experience with wiring from working on alarm systems in a commercial building, so I know how to do the basics (strip, splice, solder, seal, etc.) but as far as building a harness from scratch, I'm a little over my head. .
Also, where do I find some of the more specialized connectors, specifically the one for a 3 prong ignition switch. At some point somebody cut the one I have on there right now a little close, and his sloppy *** splice job is about to let go. I found one online for a 65 fairlane that looks similar, is it the same part? How many different ignition switches was Ford using back in the early 60's?
  #4 (permalink)
Old 10-20-2011, 03:58 PM
Customcab's Avatar
Customcab Customcab is offline
Customcab has a good reputation on FTE.Customcab has a good reputation on FTE.
I recommend checking your headlight switch; which is basically your fuse panel; and if you see blow fuses replace them; get a test light and check voltage amps etc. also if a salavage yard is close by with a 61-64 model; remove the dash harness and use it if yours a rat's nest.
I'm kinda in the same boat with a 64 model;
Welcome aboard.
__________________
Mitch
63 F100 LWB 302/AOD (Orphan box) Daily Driver.
62 F100 LWB 292/3spd (Uni-body Big Window)
57 F100 SWB 351C/FMX; (Big Window)
93 F150 4x4 Regular Cab Daughters 2nd truck
87 F150 Flairside 4.9L "Wife truck"
Tags
1963, 1966, 87, access, box, dash, f100, f250, ford, harness, truck, vintage, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
