Need help on removing the front lower coil spring support stud.
1/2 X 5/8 stud is rotted so bad the hex nut that is part of the stud is no longer hex shape. Any ideas on how to remove it would be appreciated.
1995 F150 4X4 5.0 .
Thanks
Found a solution . I mig welded a nut the same size as original to the remaining stud and was then able with a little heat remove the stud.
Hope this my help someone else.
