Wiper Problems
Wiper Problems
I have struggled for a couple of months on how to correct some whacked out wipers on a 92 Aerostar. I finally broke down and took it in to the Ford shop. Yes, the problem is now fixed but at a substantial cost. Hopefully, my experience can be useful to others and you can fix it on your own, or at least faster than the route I took.
Symptoms: Wipers began running continuously while in delay mode, and would continue to run even when the wipers were placed in the "off" position. Problem was intermitant at first, but eventually became progressively worse and required me to install a cutoff switch between the Wiper Control Module and the wiper motor to control the wipers.
What I did: I first tried installing a different Wiper Control Module that I got out of a scrap yard for $5. I then tore apart the multifunction Turn Signal/Wiper Switch and cleaned it. I checked all of the ground wires and even tried grounding directly to the battery. I then purchased a new Wiper Control Module from Ford for $71. The problem still existed, so I bought a new Multifunction Switch from Ford for $72. I had some other ideas, but decided to shift the liability to Ford Service before I sunk any more money or aggrevation into the problem.
What the actual problem was: The wiper motor has a small internal switch which detects when the wipers are in the "off" or "parked" position. While the wipers are "running" a 12V signal is sent to the Wiper Control Module via a Black and Pink wire. In the "parked" position, this signal is shut off and the B/Pk wire is grounded, draining current from the Wiper Control Module. In my case, the switch became defective in that it was no longer grounding properly, so the Wiper Control Module circuit was never drained. Therefore, the circuit interpretted this as the wipers were not in the "park" position yet, so the wipers would continue to run, even if the wiper switch was in the "off" position. Replacement of the wiper motor fixed this problem.
What it cost me: Wiper motor-$230, labor- 3 hours @ $60/hr (VERY big rip-off, considering I could have done it myself in an hour), Wiper Control Module (WCM) from scrap yard-$5, New WCM-$71, New Multifunction switch-$72.
Wiper Problems
1990 4.0 my van started doing the same thing on the highway when a semi passes a gust of wind will turn them on and i always have to stop jump out pull the wipers you said change the motor how do you get those clips off with out breaken them the plastic grill above the hood i tried to take them off but i broke one
phoneman91
62
03-13-2024 09:16 PM
OlBrownTruck
04-27-2017 04:02 PM
Gear9250
1978 - 1996 Big Bronco
02-26-2016 10:42 PM
