53 F-350 grounding
Old 10-17-2011, 04:34 PM
53 f250's Avatar
53 f250
53 f250 is offline
53 F-350 grounding
Hi all,
I just got a 53 f350, two farms old, and have a question about grounding.
The truck is 6 volt, v-8 flahead, four speed. The battery is negative grounded. It runs and guages seems to work correctly except temp which shows hot all the time.
Is this correct? What would happen if I made it positive ground as the shop manual shows?
Thanks
PS. I even got the self destructing wire insulation as a bonus!.
Old 10-17-2011, 04:47 PM
raytasch's Avatar
raytasch
raytasch is offline
Believe Nothing
Welcome to the forum.
As the shop manual shows, the 6V electrical system should be positive ground. It can be switched back and the generator polarized to work positive ground. Many times these old six volt system vehicles were hooked up neg ground by mistake. To run correctly, the coil should be hooked to match polarity and when these were hooked neg ground in error the coil wiring was not touched. If it were mine, I would hook it correctly if you are going to keep it 6volts.
Old 10-17-2011, 05:46 PM
53 f250's Avatar
53 f250
53 f250 is offline
Thanks, my 53 f250 was converted to 12v prior so there was no help there.
I intend to keep it 6v so I'll try your suggestion.
Thanks
Any other assist or experience welcome. A. Never had Ford, B. Never had a 6v, C. Never had a flathead....
1moses
12-26-2014 12:24 AM
CrazyDog66
02-13-2011 03:33 PM
John W Cina
Electrical Systems/Wiring
06-19-2007 09:54 PM
racoonbandit
18
06-24-2006 10:10 AM
gd 49
05-29-2004 11:27 PM
Quick Reply: 53 F-350 grounding
