Heater control valve location
Old 10-15-2011, 12:02 PM
koldleblue's Avatar
koldleblue
koldleblue is offline
Question Heater control valve location
89 f250 5.8 heavy duty 4x4
Where is the heater control valve i think it is stuck open because when tune the temp to cool it still blows hot air not cool air from outside. seems as if the heater is always on.
I know my A/C dose not work but still should blow cool air out from the vent position right?
Thanks in advance!!!
Old 10-15-2011, 01:16 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
If your application uses a control valve, I'm not 100% sure if the 89 does, it will be in one of the heater hoses between the engine and firewall where the heater hoses go inside the truck..
I know the later trucks don't use a water control valve, they use a "blend door" to route the air through or around the heater core.
Old 10-15-2011, 02:51 PM
Conanski's Avatar
Conanski
Conanski is offline
There is no control valve on this vintage truck it's all done with the blend door and it sounds like yours is stuck closed.. which is uncommon. The door is controlled by engine vacuum and to get to it you first remove the glove box and then the heater core cover and it should be visible.
Old 10-15-2011, 02:57 PM
White 97 xlt
Hey Paul, does the 89 have the issue of the white vacuum line that goes bad like the 90's do?
Another quick question. If the vacuum is lost, does the blend door default to heat or cool? Or does it just stray where it was the last time there was vacuum?
Old 10-15-2011, 03:11 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
I thought the temperature control was operated by cable and only the fresh air door and vent selector were vacuum operated.
My '87 uses a cable for both the temperature control and vent position selector, but uses vacuum to control the fresh air door - I know that changed, but I'm not sure in what year.
Old 10-15-2011, 03:21 PM
Conanski's Avatar
Conanski
Conanski is offline
'89 and '90 trucks should be the same though we know how that goes.
I know there is at least one vacuum actuated device in the heating system on these trucks but I couldn't tell you with 100% certainty what it is now, but in any case I bet the OP's problem is with either the vacuum or cable operated components inside the heater box... or with the controls themselves.
robenz78
1997 - 2003 F150
01-11-2018 11:08 AM
orden09
1983 - 2012 Ranger & B-Series
02-14-2010 09:37 PM
reddog99
05-27-2008 09:44 PM
cigarxtc
01-19-2005 11:27 AM
fordx94
12-23-2004 09:55 PM
Quick Reply: Heater control valve location
