Transmission Filter Change
Has anyone changed the transmission filter in a Navigator with the 6hp26 (2008) transmission? There are T40 bolts in the pan and at least one is directly under the exhaust. Just wondered if anyone has any tips? I'd hate to have to drop the exhaust just to change the filter.
Will a U-joint half cut torx socket will get the bolt off without removing the exhuast?
Thanks!
Thanks!
1996, 2004, 97, change, escape, expedetion, expedition, expediton, f150, f250, filter, ford, replace, trans, transmission
