Brake Line & Hose Pics needed
Hey guys,
I need some help with the brake part of my build.
I could use a few pics:
-pic of the proportioning valve and lines in that area.
-pic of the front axle brake hose where it's attached to the frame
-pic of axle where the line from the frame attaches
-pic of the way the hoses to the calipers are held near the inner c on the axle
-pic of where the rear axle brake hose connects to the hard line on the frame
Thanks in advance
-Justin
Thanks in advance
-Justin
Been there, done that. I'll end up with 20 or 30 pictures, but don't have the ONE I need that shows something at just the right angle.
Thanks for the pics devino. That helped me quite a bit, the only difference I have is that I don't have a line coming out of the bottom of the proportioning valve like you do since mine has a single line to the front axle and then splits off to go to the calipers. Hopefully someone has a pic of how the front rubber hose is retained before it goes to the axle.
I've seen it go through the frame and clip there but mine doesnt have a hole underneath the proportioning valve.
Here's the couple pics I have of random stuff.
My '74 F-250 crew cab 4wd - which doesn't seem stock - seems like it was messed with by a dumb PO. Steering box area was for sure done by an idiot!
My '74 F-100 2wd supercab
I thought I had a couple more pics of just the prop. valves but I guess I don't.
timothy47129
13
07-10-2006 04:20 PM
