1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Time for a transmission?
Old 10-08-2011, 05:22 PM
victorcharlie's Avatar
victorcharlie
victorcharlie is offline
I bought a 1999 F-350 crew about a month ago. It runs fine, and I've pulled a 7,500 pound horse trailer a half a dozen times and put about 2000 miles on it from the time I bought it.
A couple of weeks ago after returning home, and after backing up and going forward several times, the truck wouldn't drop into drive. It would go into first, and reverse, but no drive.
The next morning, it shifted fine, through all the gears.
It's gotten progressively worse, and today I flush the transmission and replaced the filter. The fluid was dark and smelled burned.
After I finished I took if for a drive and it shifted beautify, so I backed up and hooked up the 4000lb horse trailer. Pulled fine, drove it 40 or 50 miles and up some steep hills then back home.
Again, while backing in the trailer, which requires me to shift forward to reverse and visa-versa, the truck quit pulling, and now won't pull in first.
My guess is it'll pull fine again when it cools down.
Any idea's or do I need a new transmission?
Old 10-08-2011, 06:57 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
If its a four wheel drive it would help to put it in 4 low when backing up the trailer. You are creating a ton of heat on your trans doing it that way and eventually it will be toast.
Old 10-08-2011, 07:05 PM
victorcharlie
Good advice, I didn't think about that. So reverse is working the transmission harder than a forward gear?
twesslen
2017+ Super Duty
03-30-2017 08:43 AM
Technologiq
08-17-2014 10:56 PM
pkthomas
06-16-2010 08:23 AM
cobiyero
09-06-2006 06:16 AM
Thumper4995
06-14-2004 02:35 PM
Quick Reply: Time for a transmission?
