1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Front hitch F250 SD Lariat
Old 10-06-2011, 12:37 PM
rsanford's Avatar
rsanford
rsanford is offline
Hello out there. You all have been very helpful in the past so I thought I would try again. Is there a front hitch for my truck that will not require permanently removing the tow hooks and/or the fog lights. Thanks. Raleigh Sanford.
Old 10-06-2011, 12:39 PM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
What year?
Old 10-06-2011, 01:27 PM
Trophy_23's Avatar
Trophy_23
Trophy_23 is offline
Depending on your year have a look at the Warn front receivers. I believe you can keep you factory fogs with those ones.
Old 10-06-2011, 02:12 PM
raidscsi's Avatar
raidscsi
raidscsi is offline
Curt Manufacturing makes two models, one that uses 8 bolts and goes between the bumper and the frame, tow hooks and fog lights preserved. The other model goes between the leaf spring mounts and the frame and replaces the blocker bar if your truck has one, this one conflicts with the fog lights. I am going to install the 31114 model. $~170 on amazon.
Front Mount Receiver Hitches
31114
31014
Old 10-06-2011, 02:24 PM
rsanford's Avatar
rsanford
rsanford is offline
2001
What an idiot (I am). The truck is a 2001 F250 Superduty Lariat.
Old 10-06-2011, 02:33 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
31114
31014
that 31114 looks like it bolts to the end of the frame horns? wouldnt it be better to have one that bolted inbetween the frame rails?
Old 10-06-2011, 02:37 PM
raidscsi's Avatar
raidscsi
raidscsi is offline
Old 10-06-2011, 02:39 PM
dchamberlain
Old 10-06-2011, 02:45 PM
raidscsi's Avatar
raidscsi
raidscsi is offline
I think that the 31114 looks stronger than the 31014. Both are going to hold a winch/bike rack/cargo rack/push bar/spare tire just about the same.
Nearly all of them are rated for 500lbs carry and 9000lbs direct pull.
Old 10-06-2011, 02:48 PM
dchamberlain
It might be stronger, but it will require the removal of the fog lights, which the OP didn't want.
I have the 31114 because mine is a 2004 and the other one won't fit. And I don't have fog lights anyway. I have drug the truck with all 4 wheels locked along the ground with it and it held up. They are pretty handy.
raidscsi's Avatar
raidscsi
raidscsi is offline
Originally Posted by dchamberlain
I was wrong. the 31014 is not 500lbs
31114 Specs:
  • Line pull: 9,000 lbs
  • Vertical load: 500 lbs
  • Gross trailer weight: 5,000 lbs
  • Receiver opening: 2" x 2"
  • Pin hole diameter: 5/8"
  • Limited lifetime warranty
31014 Specs:
  • Vertical load: 350 lbs
  • Gross trailer weight: 3,500 lbs
Old 10-06-2011, 02:53 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
think i might try to make one out of a used hitch i got laying around here for the back.
Old 10-06-2011, 03:29 PM
spinella's Avatar
spinella
spinella is offline
i have the behind the bumper one(31114) i didnt have fog lights and it wont work with the factory lights with the factory brackets.
Old 10-06-2011, 04:29 PM
rsanford's Avatar
rsanford
rsanford is offline
Thanks for all the replies. So the consensus is that the 31014 will fit without having to lose the tow hooks or fog lights. If that is the case, that is what I will go with. Even though it is a little lighter duty, it will serve my purposes for an occasional bike rack or light luggage rack.
Old 10-06-2011, 04:37 PM
spinella's Avatar
spinella
spinella is offline
heres a shot of my sons dirtbikes. when i carry my dr350 i add a "drop" receiver to lower the bike out of my sight. (14" 's)
Quick Reply: Front hitch F250 SD Lariat
