how to remove clutch/flywheel ZF6
10-05-2011, 02:11 PM
how do you remove the clutch/flywheel on a zf6 trans from the motor? i have pics of what i need to get off.
10-05-2011, 02:26 PM
on
You need to remove that clutch plate first, Than you can remove the fly wheel.
10-05-2011, 02:30 PM
Yes, it appears to simply be rusted/glued to the flywheel surface.
Some heavy persuasion against the clutch disc there will separate the two.
10-05-2011, 02:34 PM
where do i perused them to come apart?
10-05-2011, 02:37 PM
Quote:
Originally Posted by
snakedoc
I would start pounding on the disk with a BFH to jar it loose.
There is nothing else holding it onto the flywheel except the adhesion of the friction material to the flywheel surface.
10-05-2011, 02:55 PM
10-05-2011, 07:23 PM
snakedoc
worked.............
How many whacks did it take?
10-05-2011, 08:55 PM
was this engine sitting for a while with the pressure plate still on? kinda wonder why its stuck on there so good haha
10-05-2011, 10:30 PM
it took 3 good ones and it fell off.
10-05-2011, 10:48 PM
powerstroker100
yes it has been that way for ~2 years. and the humidity here will rust metal in hours.
Andy_F100
09-15-2015 05:46 PM
dieselsubmariner
01-10-2015 12:09 PM
MackGuy
07-24-2014 12:24 PM
kooper909
15
04-11-2008 09:59 AM
MGolden
01-09-2007 05:42 PM
2007 ,
292 ,
change ,
clean ,
clutch ,
diesel ,
disc ,
flywheel ,
ford ,
removal ,
removing ,
rust ,
trucks ,
v8 ,
zf6
