1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Radio will not turn on
Old 10-02-2011, 10:00 AM
ajordan193's Avatar
ajordan193
ajordan193 is offline
02 f350 xl with factory cd player. I have power going to the unit like the clock but will not turn on completely. I have checked all the radio fuses and they are fine. I also swapped another factory radio from another one of my trucks and it does the same thing. Any thoughts?
Old 10-02-2011, 12:36 PM
Rongold's Avatar
Rongold
Rongold is offline
Radio
Check all the fuses with a test light. Sometimes there is a fuse that has nothing to do with the radio that supplies power to it. The owners manual usually does not show all the fuses that are for a particular circuit---only the major uses of that fuse. A few months ago, I replaced the dome lamp assembly in my truck. I accidentally blew the fuse associated with that circuit when I pulled the lamp out of the depression in the roof panel without knowing it. Besides the lamp not working when I installed the new one, the radio and the power windows would not work. As I said above, check ALL of the fuses with a test light--I'm sure you'll find one blown.
RON
P.S. The clock in the radio is on a different circuit than the radio itself.
Old 10-03-2011, 10:41 PM
ajordan193's Avatar
ajordan193
Your a genius, took all of 2 minutes with a test light to figure out the problem. Thanks again!
Old 08-27-2014, 09:23 PM
M_serrano's Avatar
M_serrano
M_serrano is offline
Same problem and on a road trip
Which fuse was it??? It would help a lot I'm having the exact problem as well! Would help a lot thank you!!
Old 08-27-2014, 09:24 PM
M_serrano's Avatar
M_serrano
F350 radio won't turn on
Can you let me know wat fuse it is please?? Would really appreciate it!
Old 10-25-2017, 07:07 AM
Harry Spohrer's Avatar
Harry Spohrer
Harry Spohrer is offline
Fixed problem
Had the same problem, went to change the dome lights on the inside of the truck, and must have blew a fuse. Took a light tester tool, and checked all the fuses. Found the fuse and put a new one in now my radio is working normal. The fuse was located inside the cab under the dash, it was a 10 amp (red)fuse at the very bottom of the panel. Which I believe was for the cluster:
Fordyarddog
2004 - 2008 F150
07-20-2016 03:21 PM
T2 HUFF
1978 - 1996 Big Bronco
02-02-2014 01:03 AM
The Blue mule
01-13-2013 05:39 PM
bradjp92
07-15-2008 12:32 AM
00Lariatman
01-19-2005 05:28 PM
Quick Reply: Radio will not turn on
