DO'S AND DONT'S
Old 09-28-2011, 12:52 PM
yamagrant's Avatar
yamagrant
yamagrant is offline
Thumbs up
Originally Posted by mechmagcn
Rear springs and hangers are from a 88 Ford Ranger. I also used a sway bar on the rear from a 88 BroncoII.
What mods? or is it a bolt in? It sure looks sweet!
  #32
Old 09-28-2011, 01:38 PM
mechmagcn's Avatar
mechmagcn
mechmagcn is offline
Springs are pretty much a bolt-on, just need to drill the holes. Sway bar is a bolt-on, even the holes are in the frame, just need to be enlarged from 3/8'' to 10mm.
  #33
Old 09-28-2011, 01:47 PM
yamagrant's Avatar
yamagrant
That's awsome! I was going to have a local guy build me some new rear springs, but Ranger's are a dime a dozen in the pick-a-part yards. I asume it was 2wd?
  #34
Old 09-28-2011, 01:52 PM
mechmagcn's Avatar
mechmagcn
I asume it was 2wd?
Yes, the 4WD springs have too much arch for the stance I wanted.
  #35
Old 09-28-2011, 01:55 PM
thepitshop's Avatar
thepitshop
thepitshop is offline
Another tip, if your using the complete harness from the lincoln, i`ve bought the factory wiring diagrams on e-bay, i did the mistake of buying the service manuals first and theres really not mutch in there, there diagrams are huge in size and have all the wiring colours, acessories all labled.
-i`ve salvaged the wiper motor and will be using it on my truck
-i`m also using the crown vic column
i`ve basically used as mutch as i possibly can off the vic to save some $$$ for the rest of the build
  #36
Old 09-28-2011, 02:10 PM
yamagrant's Avatar
yamagrant
Amen Brother! saving $$$$$ these days is tough, but you guys have given me so much help that has saved me from buying things I don't need. Thanks a bunch and keep those tips rollin in.
  #37
Old 09-28-2011, 02:28 PM
jniolon's Avatar
jniolon
jniolon is online now
old and in the way
Grant,
I was going to back up my smarty-aleck remark with some good advice.. got busy and forgot....but I see others have filled you in on baggies and pictures and such. I'd add the following
HAVE A PLAN !!!!! don't say I'll worry about that later... it's an alligator waiting to bite you in your un-awares. I'm fighting a problem now that shouldn't be one... bad planning. look ahead and write it down... what has been done, what you want to do and what the end result will be... then step thru the process and see what's involved... it will save your brain and your visa card and maybe a marriage...
keep a log of what you do and when... draw sketches and put in important dimensions if they aren't readily apparent. And if you give your pictures names on your hard drive...be specific...like 'left rear spring shackle arrangement' don't just label them 'frontend1', frontend2...
I've got hundreds of pics and 'most' have names I can choose from to narrow my search pretty quickly..some don't
if you're of a mind to and have the time/talent.. write up some descriptions of what your doing... like that Lincoln rear end install... start you a website and post them or at least get a moderator to put them in the tech article section... put the pictures you took in the articles too...
there are lots of newbies that come through here (like you ?) that want information and you'd be amazed at how many need to know what you know... pay it forward..
good luck and keep us updated on your progress..
later
John
  #38
Old 09-28-2011, 02:38 PM
yamagrant's Avatar
yamagrant
Thanks John, and pay it forward, I will most certainly will.
  #39
Old 10-05-2011, 12:17 PM
56FOneHundred's Avatar
56FOneHundred
56FOneHundred is offline
I love the Ford Ranger spring idea...I was going to pay a local spring shop $85 a spring to rebuild them, but I may go the Ranger route instead. Thanks Jeff.
SummerBreeze2
27
11-11-2015 06:04 PM
AWS_48_f2
22
01-26-2013 11:01 AM
Myfat52
20
08-04-2012 09:32 PM
rumblewino
06-01-2004 08:44 PM
pollock
03-01-2004 09:24 PM
Quick Reply: DO'S AND DONT'S
