Confused with 7 pin trailer connector
I do not understand what is going on with my trucks 7 pin connector. I have tested each pin by the ohm meter with someone in the truck working brakes/blinkers. It does not make sense. I had to put a new connector on my horse trailer. The problem is, the wires broke inside the trailer's connector so I can't tell what went where. But the truck side is not helping me figure out what to do.
Question 1. Isn't there supposed to be a pin that shows 12V only when the brakes are applied? I would assume this goes to the trailers brakes. There is not a pin on the truck that gets hot with brakes applied.
Question 2. Isn't there supposed to be a pin that shows 12V when the lights are turned on truck? I would assume this goes to the marker/running lights on the trailer. There is not a pin that gets hot when lights are applied.
Question 3. Why would the truck have 2 pins that show 12V at all times? All wiring diagrams I have read online only show 1 pin with a always hot 12V.
Note - left turn, right turn, and brake lights work
Did you check the READ FIRST posts at the top of this FORUM??? There are wiring diagrams up there......http://www.ford-trucks.com/forums/59...0-13-10-a.html
truck not behaving per diagram
Here is what is how the truck connector is behaving.
1. Ground - correct
2. Brakes - incorrect, always 12V. Shouldn't this only be when brakes are applied?
3. Markers - incorrect. Does not show 12V when the truck lights are turned on. Shouldn't this be 12V with truck lights?
4. 12V Aux - correct
5. turn/brake - correct
6. turn/brake - correct
Could a relay or fuse on the truck be causing these symptoms?
1. Ground - correct
robs01f250
07-29-2012 06:01 PM
AlaskaPowerStroke
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
07-26-2004 01:21 PM
