Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 09-26-2011, 06:38 PM
10sne1 10sne1 is offline
Garage is empty, add now
10sne1 is starting off with a positive reputation.
towing problems
The last two times I have towed with my wife's expy EL it has shuddered a few times at low speeds. I only tow approx 5000# boat approx 3 miles. The speed I travel is up to 40mph. It will shudder just a few blocks thru out the trip. It has 48000 ,iles and the power train warranty is good to 50k. So I need to find out what is covered under the power train? I really dislike dealers but seems I need to take back to them as it could be a warranty issue. Thanks for any constructive thoughts on the topic. Tomm
  #2 (permalink)
Old 09-26-2011, 06:55 PM
RI-Matt's Avatar
RI-Matt RI-Matt is offline
RI-Matt is starting off with a positive reputation.
Could be a coil. I had a few go on my old 06 F150 and it would shudder like bucking horse . If it is a coil, it's not covered under any warranty.
Matt
  #3 (permalink)
Old 09-27-2011, 07:37 PM
is a coil easy to check? Cost?
  #4 (permalink)
Old 09-28-2011, 11:23 AM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
Are you sure it isn't the receiver moving around? There is typically a little slack for the hitch and receiver. I always get a little bump when starting, stopping, or bigger bumps
Or, do you have a 2 5/8" hitch on a 2" ball?
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #5 (permalink)
Old 09-28-2011, 08:22 PM
yep, wish it was the hitch, even told my self it must be the hitch. But no luck it is in the expy. So off to the Stealer ie dealer to see what BS they can drum up or mess up. Sorry history tells me that dealers are in it just for the minimums per vehicle they fix. ie $600 average per vehicle that goes thru their work bays, wish I did not believe it, but that damn history tells me different.
  #6 (permalink)
Old 09-28-2011, 08:42 PM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
thinking outside the box a bit
how about the trailer itself? are the tires flatspotted? does it have electric or hydraulic brakes that might be grabbing initially?
sometimes it's the stupid things that you don't look at. I'm assuming your Expy doesn't exhibit this behaviour any other time.
I'm interested in your trailers brakes. I know from experience that if you park it relatively quick after loading/unloading the trailer and let it sit for a while, the brakes will "freeze" up from slight corrosion. I let a trailer sit for 1 yr once and boy was it bad getting the brakes unstuck.
__________________
  #7 (permalink)
Old 09-29-2011, 04:32 PM
I really want it to be the trailer too! But it is just not the case. I did find out the dealer I plan to use is very good! I'll keep ya posted....
  #8 (permalink)
Old 09-29-2011, 06:10 PM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
good luck. hope it's nothing bad or expensive
__________________
Tags
expedition, problems, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
