LEAF SPRING ????
LEAF SPRING ????
I own a 97 f-250HD that has a 4/1 rear leaf spring suspension, when i looked at the pad measurements its the smallest capacity spring they used on this model, being 2490lb. My truck is the 7.5 liter engine,4x4, crew cab, short bed. My question is if I was to put a 5/1 or 6/1 leaf system on this truck would the ride be softer when Im running down the road empty? I know that it would stiffen considerably with a load but Im mostly concerned about empty load considering thats mostly what the truck sees.
I hate to thread hijack, but how did you come upon the information that your leaf springs were small? I wasnt aware there were any measurement specs on these springs, I mcurious as to which ones mine has. My f350 is sitting on its overload springs and I was about to start looking for replacements, any information on what you already know about spring ratings would be helpful. But, to answer your question, adding leafs will stiffen the ride considerably, especially empty. They put in a smaller spring set because you have a short bed. Unless you are planning on towing a fifth wheel or filling that bed to the brim with rock, I would probably stick with the size of leafs it already has. The more leafs it has, the more stiff it will be. Especially empty. Trust me, I know, I haul loads of all sizes all the time in my bed and I tow because I use my trucks for a living. If you are looking for less stiff of a ride, I would buy a f150!
94windsor
11-30-2018 06:24 AM
abcat12
06-20-2006 02:36 AM
Big Red
06-17-2003 10:52 AM
