idling at 3500 rpms
idling at 3500 rpms
ive been having this problem for a while now. my truck used to only idle at 3500 when it was cold, but lately its been doing it even when warmed up. sometimes it doesnt stop until ive been driving around for 15-20 minutes. its almost dangerous. i have replaced the tps, fpr, iac, cap, rotor, wires, plugs, coil, and i cant find any vacuum leaks. i have cleaned the throttle body numerous times and the cable isnt sticking. sometimes if i blip the throttle it will go away for a minute or two but then come back. i dont know what else it could be. truck is in sig.
My truck idle sticks also.The guy I brought it from said that was normal
(bull----).
I replaced ever thing under the hood.
I think mine is the computer. What I been doing for almost 3 years is each time I start it(cold and hot) I tap the gas pedal right when the motor starts. It works about 95% of the time. If it is still idle high I shut it down and redo above step.
(bull----).
(bull----).
(bull----).
on
Generally no excapt that it is attached to the vacuum system, but the line is pretty small so I doubt that is your problem. What happens if you start the motor and get it idling(screaming) at 3500rpm and unplug the IAC or TPS individually.. meaning not at the same time? Does this have any effect on the idle speed? Have you tried disconnecting and plugging the vacuum line to the brake booster?
i had the same isssue, but i can't tell you what my RPMs were since i don't have a tach. anyway, after tearing it down to the intake and having my friend with a ton more experience and know how dig deep and search, the thing we finally stumbled upon was the new TPS (2 wks old!!!) was not reading right on the multimeter. now with the new one in, i haven't had the idle surge problem. just gotta clear the codes that were stored to make sure it's running properly. all that to say this, try checking your voltage on the TPS.
i did my codes today and got 122 and 327.
122- throttle position sensor below minimum voltage
327 - evp/ept circuit below minimum voltage
i cleared the codes and kept getting these a few days in a row. im assuming my tps is bad, and i guess my egr valve sensor is also bad? rockauto refers to it as the egr pressure feedback sensor.
oldproudvet
11-01-2018 07:29 AM
XRayAlpha
27
02-11-2018 02:48 PM
